HangOutdoors
- Royal Oak, MI
Yes, TV’s, but only help at wake speedDo you have fins on it?
You need CJS fins. At WOT it tracks straight, no slop. When you turn it grabs good.
[/QUOTE
I may go that direction. I’ve only been out twice. Going to give it some more time. Thanks
My parts list if anyone is interested.
Amazon.com: Blue Sea Systems 7650 Add-A-Battery Kit, Beige (7650-BSS): Sports & Outdoors
Amazon.com: Blue Sea Systems 6 Circuit Blade Fuse Block With Negative Bus 100 Amp Max Per Block 30 Per Circuit: Automotive
Amazon.com: Blue Sea Systems 150 Amp Common BusBar with 4 studs and a cover, 2307: Sports & Outdoors
Amazon.com: YMHTD 100A Reset Fuse 20-150AMP Inline Circuit Breaker Reset Fuse Holder for Car Audio Marine Boat Inverter Replace Fuses 12V-24V DC Breaker Switch Overload Protection Fuse: Automotive
Amazon.com: YMHTD 60A Reset Fuse 20-150AMP Inline Circuit Breaker Reset Fuse Holder for Car Audio Marine Boat Inverter Replace Fuses 12V-24V DC Breaker Switch Overload Protection Fuse: Automotive
BLUE SEA SYSTEMS Cover for MaxiBus 2105/2126 (For Models 335904 and 13176383) | West Marine
ANCOR Battery Cable by the Foot | West Marine
ANCOR Flat Duplex Wire by the Foot | West Marine
I had the same questions for @HangOutdoors, and the covers fit either BusBar. My set up is basically the same under the helm as well. He helped me immensely, and trust me, "He knows what he's talking about". ?I got a couple of questions for you.
1 - The Blue Sea System Cover you got on this list seems to be for the Blue Sea System 2105/2126 which is the MaxiBus 250A BusBar. But instead you have on the list the 100A MiniBus Bar. Is there a mistype somewhere here or are you actually using the 250a cover thats meant for the MaxiBus 250A on your 100A MiniBus Bar?
2 - You are using the Blue Sea Systems 6 Circuit Blade Fuse Block With Negative Bus which its pretty cool, but you are actually mounting this unit at the battery panel instead of the back of the helm. I would think it would probably be a cleaner install at the back of the helm (less cables going to the battery panel for accessories) unless you doing that cause its cheaper than to run 1/0 AWG cables for power and negative from the battery panel to the back of the helm?
Im trying to use your same setup as you so all the help its appreciate it. Thanks
Thanks to @haknslash
White/White King Starboard Plastic Sheets Cut To Size (boatoutfitters.com)
And here is what came in. I ordered Black and White
Interesting!! ThanksI dunno if the size will work, but if you're a member of Sam's Club, they've got these cutting boards that will save quite a bit, and will accomplish the same thing. I used two of these to fab up a riser for my cleanout hatch, they can be machined with any woodworking tools
Member's Mark Extra-Large Commercial Cutting Board, 15" x 20" - Sam's Club
Buy Member's Mark Extra-Large Commercial Cutting Board, 15" x 20" : Cutting Boards at SamsClub.comwww.samsclub.com
I thought about the cutting boards too, but only after I spent like $70 for a 12" x 24" 1/2" piece of starboard at West Marine. (Taco Marine)I dunno if the size will work, but if you're a member of Sam's Club, they've got these cutting boards that will save quite a bit, and will accomplish the same thing. I used two of these to fab up a riser for my cleanout hatch, they can be machined with any woodworking tools
Great looking setup. What gauge wire did you use from the battery to the switch/ACR/buss bars? I have this same switch/acr but haven't installed yet. New to this and learning before I tackle it. I've bought the battery, switch and am now looking at cable. Had some 1/0 cables made at 2' each but they seam like overkill.
Also, my plan is to run my amp to the secondary (house) battery, would I need to find the head unit power and run that to the house battery as well? Lastly, I also have a NOCO 10 amp (5 amp per bank) charger I plan on installing and plugging up after each weekend at the house. This wouldn't interfere with the switch/ACR setup would it? The switch would be off as soon as leave the water.
There are a lot of extra fuses I wasn't accounting for. Start isolation being one of them and the ground from the ACR being the other.
