yamahasrxman
Finally got the new SVHO intercooler in on the weekend. Also added new billet 45° thru hull fittings for the extra line on the new intercooler. Will be out on the water in two weeks( ) and will post results.
Thanks,Looks great, I'm going to do the 4 pissers as well, maybe not at first.
Thanks,
I was skeptical at first to drill into a new boat but was pleasantly surprised how well it went. I used a diamond tip hole saw to prevent chipping of the gel coat. Measured about ten times to make sure the spacing was equal and dove in..
Next up. Ribbon delete.. and try and find ethanol free fuel.
All the fittings are 3/4" outlet so I didn't have to change the bilge line.. The hole I had to drill to accommodate is 1"
#4 is the bilge.What are the four pissers for? We have two stock, one for the intercooler outlet and one for the engine outlet (I think). I know the upgraded intercooler adds the need for a third outlet, but what is #4 for? I'm going to start working on my install tonight.
Should have 3 outlets from factory.
1 for bilge, 1 for intercooler ,1 for oil cooler. The 4th is for the extra line in the upgraded intercooler.
Been reading up on modded 1800 super charged skis and wow for not a huge chunk of money they are hitting low 80s. I wonder if anyone has put the time and money into a 192 yet to see what it can really do with 300+HP. Would it hit 60mph with the same sort of mods as a low 80s skis?
You would need the 160mm pump, too. 195.Been reading up on modded 1800 super charged skis and wow for not a huge chunk of money they are hitting low 80s. I wonder if anyone has put the time and money into a 192 yet to see what it can really do with 300+HP. Would it hit 60mph with the same sort of mods as a low 80s skis?
