Proper gate adjustment for Neutral?
Listen up Everybody (saying that nicely).....your dealer can adjust this from happening. Tell them to read the darn manual and set it accordingly! It shouldn't be just taking off. It will creep for a second at first start since the initial idle is high, but not to where you are losing control of the vehicle.
Ron,
Do you or can you sell the manual you are speaking of?
If not, can you attach a .pdf of the page that addresses the adjustment?
Walt
normal break-in, self adjusting, what a disappointment, tell us the name of this dealer so no one goes there again,
@Ron@Scarab can you confirm the only adjustment is the "rotating the key" mentioned above
We need to get an post on this for the FAQ, the yamahas are not difficult at all to adjust,[/QUOTE
The IST or INR (New name for IST---Legal reasons) models are set by the dash (if available) on the gauge cluster, or the dealer as I've been recommending has to adjust it on the BUDS system on the water to correct that issue.
Okay for some reason my post didn't go. The IST or now called INR should be only properly set through BUDS from your dealer on the water. If your boat is equipped with the adjustment feature for a proper neutral, you can adjust at the helm on your gauge cluster.
Unless you're aware of a different adjustment than the one I described above, where you have to rotate this 'key', I'm told by the dealer there are no other fine adjustments. Unfortunately for me, adjusting to a neutral position at start-up doesn't allow the gates to fully open under throttle. Because of this, I've had to resort to living with the forward momentum on startup. I deal with it by starting the boat with one engine, immediately pull the throttle partially in reverse to get the boat to stand in one position, push off, steer clear of the dock, drop back to neutral and then start engine 2 so when I go lunging forward, I'm clear of obstacles.
Here's a picture of what I'm describing as the "Key". You can see that it can only be rotated a full 360* in either direction, lengthening or shortening the shaft which controls the pitch on the gates.
I wouldn't put it past the tech's or this dealer that there are other adjustments that can be made, that they have no clue of. So really, appreciate any insight anyone has!
That can be adjusted accordingly, but you'll have to loosen the cable lock to slide the cable in and out. First, the system should be adjusted on BUDS at your dealer!!! If that isn't helping as it should, only then should the tech make an adjustment there.
Ron,
Are there Scarab tech/maintenance manuals available to purchase for end users like us?
Walt
UPDATE.... Talked to the service manager at the dealer ship. He apologized for the in short the stupidity of the service tech guy. He agrees with Ron, they will have to look at it and see what they can do. I previously discussed it is kind of a trial and air to get it right. However he ensures the issue can be corrected some.
Good to hear!!
Ron,
Walt
There is an Operator's Manual that you should've received at the time of delivery from your dealer. As for an actual Scarab shop manual, we only have our parts diagrams and specs not open to the public. The manuals from BRP/Evinrude are geared strictly for the engines and drive-line. We use our dealer ports BOSSWEB for that. If I personally can't get the info I need for a certain issue, I will resort to some of our BRP/Seadoo manuals.
Ron, I did receive an operators manual but was looking for a shop manual and that is not available I guess.
While I have you here,
1. On the Viper II Controller there is a Wi-Fi antenna. What is this for? (My iPhone connects via Blue Tooth)
2. There is also a Panel Assy, Video, Viper II (025-5112) What is this for? Does the Viper II allow for a video input from say a Go-Gro for display on the touch screen?
3. I purchased the Navionics Marine and Lake charts SD card and was told the Viper II will only accept a max of 2MB on the Card. The card that was in the slot from the factory was a Kingston 8GB SD card. I am confused as to why the 2MB limit and what the 8GB SD card is for? There are two card slots and both occupied from the factory with SD cards. Is one card an operating system and the other a mapset?
4. Is there a Manual on the Viper II Medallion and touchscreen? I did not get anything from the dealer covering this.
(2016 215 HO Wake)
Thanks,
Walt
(2016 215 HO Wake)
Thanks,
Walt
Walt, I will be the first to tell you that I am terrible with electronic gadgets. Electronics are like computers for me,....just to slow for me, lol! I uploaded some things to help you here. Let me know if that helps and if it doesn't I will get a better answer for you.
Ron,
You have uploaded 4 files with different file names but all with the exact .PDF content. The document is a user guide for the touch screen and will be very useful. Do you have other documents that cover other parts of the boat, particularly of the Wi-Fi aspect? Engines?
Thanks for the upload. You have greatly helped those with the touch screen!!!
Walt
Ron,
Walt
See, I told you I am terrible with electronics, lol! I thought I had actually copied each separate page separately, but I see it saved the whole package. Either way, it will be helpful to someone. I will check into the Wi-Fi aspect. Usually everything that covers that is given at the time of delivery. Stay tuned!
Thanks Ron, very helpful!
Walt
If you ever do adjustment to improve idle on a mechanical system, always make sure the gate still "lock" in full forward position.
Thanks for the help Ron. I'm not sure what "BUDS" is or the cable lock you bring up? I've been manually adjusting just by turning that key, no other tweaks. Is spinning that key just a waste of time without loosening this cable lock? I tell ya, it definitely does something, because one turn one way it wants to launch off the ramp, one turn the other way and the thing won't lock the gates full up.
Sheesh, I hope I haven't damaged anything...
The cable lock is located in front of the brass bracket holder you are turning. The cable lock screws into the pump support. That cable lock holds the cable in place preventing it from moving in and out. You can give length or shorten the length of the cable coming out for added adjustment. BUDS, is the software at your local dealer that they use to adjust the issue you're having. If that doesn't fix the issue, they will have to measure things out and re-set it with a water test.
Excellent. Thanks again.
