WREKS
- Port Saint Lucie, Florida
- SX
Did you see any signs of water intrusion on the EM gasket. If not, try leakdown?
I didn't read your previous threads so this may have been covered. Did you do any disassembly of the bottom end or just remove engine and have head redone ?
Bottom end unretouched
How did you apply permatex ?
TDC for #1 and #4 are the same. TDC for #2 and #3 are the same, just 180 degrees from #1. I use a wooden dowel to determine TDC for #1. To the best of my knowledge, I think, even close will do. Better still follow the service manual. I do not have a dial gauge. I do not think it is necessary. Keep reporting!
