hapyfishrmn
- Springfield, Illinois
If you like the fast....get a 192/195. Much more potential for speed there.I'm ok with anything as old as 2012 when they first started making the single engine boats. Are they always in short supply or is this an odd year because of COVID? I can wait until next year if I don't find anything. I'll just keep cramming people into our glorified jet ski! But at least it's fast...
I've never driven one without (I have a '17 with the AK), but I don't think it adds significant advantage. The adoption rates (at least anecdotally) of aftermarket steering aids appears to be about the same both before and after the AK introduction. So it can't be adding that much to the experience.They added the articulating 2016, is that worth waiting to find a 2016+ vs 2012-2015?
Good call. I forgot about the cleanout plug redesign, that's a big deal IMO. The new design is much more robust IMO.After 2016 the cleanout plugs were redesigned and there was a timing chain issue that was fixed on the 2015 and newer 1.8 engines.
So is the timing chain just an issue with the SVHO engines? I'm only looking for the AR/SX 190s. And what makes the redesigned cleanout plugs better? Easier access? thx!After 2016 the cleanout plugs were redesigned and there was a timing chain issue that was fixed on the 2015 and newer 1.8 engines.
They can be parked in a garage with a few very very simple modifications to the tower. Use the search function and you will find some great info on how to do that. That is a standard 7 foot garage door that I fit mine in due to the info I found on here. And the main reason I bough a 19 footer to store.Also trying to make sure I understand differences between the SX and AR190. The tower of course and I think the seating is different from what I've read. I'm assuming with the tower, the AR190 can't be parked a garage. Do people find the covers for them are adequate if left parked in the elements all fall, winter and spring? I live in rainy Oregon, so the boat would only get used in the summer. I'm assuming that removing the tower to store it would not be an easy task?
Here is a great thread by haknslash. You can VERY EASILY modify the tower retention cable stops to allow the boat to fit in a traditional 7ft opening. My opening is right at 84.5" to the weather stripping and I miss by just an inch or two going in and out. My tower sits all the way down and rests on the steering wheel, and lightly touches the port side window.Also trying to make sure I understand differences between the SX and AR190. The tower of course and I think the seating is different from what I've read. I'm assuming with the tower, the AR190 can't be parked a garage. Do people find the covers for them are adequate if left parked in the elements all fall, winter and spring? I live in rainy Oregon, so the boat would only get used in the summer. I'm assuming that removing the tower to store it would not be an easy task?
Not to hijack the thread, but @2kwik4u I NEED a link to that Cooler, or the local store you purchased at (I'm in Indiana as well).Here is a great thread by haknslash. You can VERY EASILY modify the tower retention cable stops to allow the boat to fit in a traditional 7ft opening. My opening is right at 84.5" to the weather stripping and I miss by just an inch or two going in and out. My tower sits all the way down and rests on the steering wheel, and lightly touches the port side window.
I did this within 15 min of being home after purchasing it. My driveway slopes pretty heavily down and away from the garage, so this looks better than most. I don't remove the bimini any more and it still clears on the way in without a problem.
I'm fortunate to have high ceilings in the garage so I can put the tower back up once inside. If not, then either the cable stops need to be added back (and lengthened), you you can build a quick support to hold the tower weight off the steering wheel. Here is a post with the parts I used.
The seating is the major interior difference between the SX and the AR. The AR has wrap around seating, or "J seating", while the SX has a second captains chair. I like the J-Seating myself, it gives us a little more storage under the seat (We have a slim cooler, and shoes that go there). The 192/195 boats (both SX and AR) have SS cupholders instead of plastic, and aluminum grab handles instead of rubber/plastic. Those can all be swapped out later if you like. I think they have nicer speakers and stereo as well. Here's a shot of the interior on my '17 AR190, and the tiny cooler that fits under the seat. It's not really tiny, just slim height. Works amazingly well.
View attachment 123116 View attachment 123117
The only "big ticket" item on the 192/195 series IMO is the supercharged engine and possibly larger jet pump. All the 190's have a 155mm jet pump, and I think the 192's do as well. The 195's moved to a 160mm jet pump. The rest of the features can be added/removed/changed later if you like.
I've left my boat outside a number of nights for various reasons. Maybe 15-20 overall. Even in a torrential rain, the interior stayed dry. This was during a rainstorm on vacation last summer in TN. Full on summer thunderstorm downpour in action. I pulled the cover back to go out later and the carpet was still dry to the touch. Now, on the expressway while towing with the same cover on, the water pools in the bow and will "soak through" the cover and drip into the bow area. Once that is saturated, it runs back into the ski locker drains, and eventually out the back. Not a big deal, but if you're storing it for a long period, make sure the anti-pooling poles (or you use the "hangtyte system) are in place to keep the water running off. If I was storing outside often, then I would most likely coat the cover in a hydrophobic silicone spray a few times a year to help with water runoff. I have zero data for you on how the cover holds up to sun. We tow with it on, always, and we're on season two and it still looks like new.
That's the one. Bought from Amazon as well. Have a green one in my cart now to use for food/snacks/etc. You can easily fit 9 cans, and then probably another 10-12 bottles of water on their side with some ice. I'll take a pic the next time I load it up. It works REALLY well for not making people move from their seat when you need a drink.Not to hijack the thread, but @2kwik4u I NEED a link to that Cooler, or the local store you purchased at (I'm in Indiana as well).
EDIT - I found it. Here is the link for anyone else interested: https://www.amazon.com/Coleman-24-Can-Stacker-Portable-Cooler/dp/B002BMCLMU/ref=sr_1_1?dchild=1&keywords=coleman+party+stacker&qid=1592485452&sr=8-1&th=1
Speaking of which.....I spent a great deal of time and effort to minimize the amount of "getting up" that people have to do when on the boat. It REALLY helps when you have a full load of passengers. Just the wife and I, and our two boys it's not bad. Get another family of 4 on board, and getting into seat compartments becomes a pain in a hurry. Lines are in a laundry bag behind the drivers seat on the floor. Bumpers are in the ski locker with lines already attached. Coolers are currently under the seat for drinks and a soft sides on the floor at the drivers feet. Vests are on kids, or in the top of the ski locker for adults if needed. Snacks are in the passenger side helm storage door, near the front, in stackable totes. Towels are in the drivers side helm storage near the front. Infrequently accessed items in beach bags, water toys, floats, things like that are in the underseat compartments. We work pretty hard to make sure we're not constantly asking people to stand up/move. Makes it SOOO much easier when docking/rafting up, as well as just generally getting into things when stopping for lunch/etc.
Taking some time to think through those things, IMO, really helps maximize the "large boat feel" out of a 19ft. We've had no complaints on space when having (4) adults and (4) kids aboard. Those kids are usually 9,7,5,2 in age, so they're small, and sticking all 4 of them in the bow is no problem, and they're glad to have their friends nearby. That leaves the full cockpit for the adults, which is still pretty roomy as long as you don't mind playing footsie on accident a few times!
I found these totes at the local Dollar General for $1/ea. They will HANDS DOWN change the way you organize your boat. Same for the drawstring laundry bags. I think they were $3/ea at WalMart.GREAT info! We are really on our first full season with our AR190 and making everyone get up to get to things is one of the things that I am learning to hate (and why I was interested in your cooler). Thanks for taking the time to reply!!
Dont forget the trailer on NADA that 1100 more $
