- Florida
- Other
- Other
So here is some food for thought.
So let's talk about jet propelled water craft.
A pump provides thrust and a nozzle directs that thrust .
The jet thrust wants to hold the nozzle straight causing the boat go straight.
A mechanical device like a steering helm or even a tiller can turn the nozzle redirecting the water jet to change the direction of the boat.
Most boats use a helm and cables to redirect the jet nozzle in order to steer the boat , thus the boat is being controlled by redirecting the jet of water exiting the steering nozzle.
Now on a twin engine boat you want the nozzles to be parallel to each other for the most effect and efficiency. The more you angle those nozzles inward or outward the less effect the pumps have causing the setup to lose efficiency.
This breaks down to a loss of top speed a loss of steering response and a loss of fuel efficiency.
All side effects that are not really desirable.
Now understand that some jet boats and P W C s use the jet nozzle to trim the hull. I have that setup on my Yamaha p w c s .
Trim is accomplished by simply aiming the nozzle up slightly causing the back of the hull to push down and the front of the hull to go up.
I use this in rough water conditions .
The opposite is aiming the nozzle down slightly , this angle lifts the back of the hull up forcing the front of the hull down.
This angle usually reduce top speed as it creates extra drag plowing the hull in the water It also makes dealing with waves more difficult .
There are situations where this angle can be helpful perhaps you have a hull that likes to develop a high speed hop , some jet skies do this and having trim to push the bow down can eliminate this issue .
A situation where I personally use a downward angled jet nozzle to lift the back of a jet ski is when I am operating in a minimum wake zone and the water is very shallow, I do that to keep the back of the ski higher to avoid sucking in weeds or trash and sand etc from under the ski while I travel through the shallow water at slow speed, it is especially helpful when you have a passenger.
That being said I avoid aiming the front of the hull down during any normal operation as it creates unnecessary drag , burns more fuel and reduces top speed and it can cause over steer. So having the direction of the water exiting the jet nozzles modified all the time is probably not the best way to get the most out of your boat or P W C.
