haknslash
- Lake Martin, AL
- Moomba
- Other
5/8" is about what the barb size would need to be to make the stock hose snug and tight on the barb. A 1/2" automotive/heater hose fits tight against the intercooler outlets but the stock hose is a slightly larger and more flimsy size due to thinner wall. so it's a toss between the two unless you really wanted to run all need hose of the same material to the pissers. The stock hose will fit a little loose on the 1/2" barb but if you use the stock clamp it holds just fine, no leaks on mine. I was more surprised by how thin walled and flimsy the stock hose was compared to the 1/2" automotive heater hose I used.
