FSH 210 Sport
- Tranquility Base
- FSH Sport
Thanks for all the input guys, I have already talked to a couple guys at Yamaha again and they suggested I take it back to the first dealer I was going to as they are now under new management and supposedly doing better. Oddly enough my starboard engine started the first time when I took it out yesterday. I am beyond frustrated that they told me they did all these checks and could not duplicate and now for the first time since probably April or May it has worked! Hopefully that part is fixed, but my display is working again and I was getting 7200 RPM on the Port engine and 7000 on starboard. So something they did made things better, I still wouldn't call it fixed as I am still topping out at 36mph (which is also faster than the 32 I was getting previously to dropping it off) and for being at sea level those RPMs are still on the very low side.
Glad to hear that there is some improvement, but as you state the rpms are low and should be closer to 8000 on a cooler day at sea level. What was the temperature the last time out?
Hopefully the “new” old dealer will be better…
I can understand your frustration, believe me I can, but, the goal is to move forward and get your engines performing as they should be.. trying not to be preachy, but put that stuff behind you and crack on. Doing the water test with the mechanic is paramount in my mind.
The mechanic should be checking that the ETV (electronic throttle valve) is opening all the way, this is a procedure in the manual.
How’s the oil level? Did you check it with the dip stick screwed in? I think it is important to rule that out straight away.
