- Northern Vermont Lake Champlain
- Other
- Other
- Other
I keep my boat in a covered lift. As it sat outside in the driveway all winter, I have rainwater in the boat. Appears when I go out I end up with water in the head compartment, that I assume is still rainwater that I have not been able to get out of the double hull. I'm assuming when I drop the hammer and pull the front of the boat up, it seeps in the head compartment.
If you can indeed see water through the ski locker drain hole, could I not use my oil change pump and stick the wand in the drain hole and suck that water out that way? I think once I get it out, I'm good as I don't end up with rainwater in the boat anymore.
Yes, you could use the extractor to pull it out. I used mine to do that in the well under the engine in the Beneteau when the water pump seal was leaking. On the Yamaha I taped a piece of tubing, that fit down the hole, to a wet or dry shop vac. It was quick pulling out 2-3 gallons that was down there.
