Roger Vrooman
- Navarre, FL
- FSH
Again not knowing anything about your TM, the next time that happens, try hitting the propeller symbol on your remote and or the MFD to see if that gets the prop going.
You should not have to re boot the troller each time.
Did you try just hitting the stand by button again to bring it out of stand by?
I have tried the remote once or twice and have not gotten it to connect with the TM yet... Sure that is something simple like batteries, or plastic tape between the batteries and the connectors... Really haven't fooled around much with that, BUT, will make that a priority before the next trip....
I'll I've done with the MFD is to hit "standby", which disengages the prop, stowed TM, gone to new spot, redeployed TM, hitting either "Anchor Here" or "Anchor Heading" (or whatever it is called ;-)) and then "engage"... Each time nothing, will try another TM menu on MFD, then "engage", and nothing until I reboot the system...
I'll get it figured out, and it was WAY better last time using the TM than the first time, and sure 3rd time will be even better ;-) Didn't even check battery usage on last trip ;-)
I plan to take some vids on the next trip of each time dropping the TM so the experts can better see what I am goofing up ;-)
Thanks much
vr
Rogman
