Seadeals
- Greenville, South Carolina
- SX
What about that filter in your air box under the injectors? If that is saturated with oil, wouldn't that over pressurize your valve cover? It has to breathe.Well, the seal popped out a bit at the end of the head where there is a half circle indent in the head, so it's a pretty big hole that sprays oil. Spoke with SBT, and they are sending me a new gasket. It's not gushing, more of a fine mist of oil, but it's all over the place.
Cybuch- Just had 2 SBT New Motors installed and picked up from Mechanic yesterday. Best advice on breaking in and what to look for before 2yr warranty is up
Thanks Cybuch and I sure hope YOU and I finally are back on the Water with NO ISSUES!!! Been a great boat since I purchased Brand New and now paying for allowing friends & Adult Kids/with Friends take the boat on many trips with out the one RESPONSIBLE for the boat. But a great 15yrs!!!Just follow their instructions for sure! Also, keep an eye out for oil leaks.
Good news and well, good news. I figured out it is water by dripping it on a hot plate. The other good news is I found the issue and @itsdgm was on to it. It was the water pipe coming up fro the valve cover. No only did the o-ring fail but the valve cover gasket did as well. The o-ring was leaking and the rubber stopper around the metal tube held the water in there until it was forced into the valve cover. I will be leaving that rubber stopper off and removing the other one as well (at least I will have a visual of water leaking from the o-ring and save me some time. I didnt need to pull the motor, but glad I did so I can get all the bad oil out of there in one shot. Here are a few pictures:
