biffdotorg
- Pelican Rapids, MN
- Limited S
I’m not an expert on these marine engines, however I am a Master Auto Tech. Typically higher rpm misfires/ under heavy load is due to a coil failure or spark not being hot enough under those conditions. Don’t think cavitation would be an issue once on plain.
This sounds more accurate than what they are recommending. Cavitation due to pump wear is a whole different issue, but that is not denying that there may be cavitation issues as well.
Anyone wondering why a pump rebuild is not covered by warranty has to understand, that it's not something that just fails, it's usually from abuse. I'm not pointing fingers, its just that the pump needs to pretty much get damaged, it is that durable. But any dealer that wants to charge you for it, should be showing you pictures of what the damage is, and what may have caused it. They don't just fail (except in the rarest of occasions)
Most common pump damage is not from sand either. Yes, sand can wear down a surface, but it's rocks, stones or hard objects that have to go through the grate, through the impeller and grind away at the pump walls to cause enough damage to warrant a rebuild of the pump. Otherwise, they have to give you some sort of indication of what they consider a rebuild. That being said, the pump walls do not usually get damaged without any indication of damage to the impeller. It's nearly impossible for something to blow past the impeller blades without damage.
So call BS on the pump rebuild without pics, and suggested cause.
