I_do_WRK86
- Limited
Boat is a 2012 242
Last weekend I took the boat out and got a CEL (port engine) on my way out to our local beaching area and it stayed for the whole ride back (about an hour both ways) but had no issue with power and no issue starting the boat until I got it on the trailer. I had a bit of a vibration issue but nothing serious. I turned the engine off, it never shut itself down. I'm currently in the process of changing my intermediate bearing and wear ring (other issue that needed to be fix), but first I'm trying to work out a starting and bad idle issue on my port engine.
As it sits right now it is cranking strong; turn key, comes off starter, idles for less than a second and dies on first try. On the second try it cranks but it doesn't come off the starter. I can let it wait for a second (key in off position) attempt again and it will act like first cranking attempt. When it does act like the first attempt I can catch it with the throttle and it responses without any issue, but when I pull the throttle to idle it vibrates a bit excessively but smooths out and will stay running(CEL still remains). IDK if there is a limp mode or how it acts in limp mode (no throttle limitation/no power loss, planed like normal). Starboard engine has no issue at all.
Things I've worked out/changed
1) Spark plug
2) Fuel lines clear
3) Fuel pump works
4) compression is fine (all around 160) 200 hrs on engine
5) changed oil in April this year
Thing I haven't worked out yet
1) The CEL
2) Any more Fueling issues (pressure , injectors, etc)
3) Timing (doubt it slipped a tooth/ personal experience with other engines)
1) Spark plug
2) Fuel lines clear
3) Fuel pump works
1) The CEL
