WildCatFan54
- Lexington , Ky.
- 242 Limited S E-Series
Was doing some house cleaning on the boat this morning. Last weekend was the first time since buying the MY19 242 Limited SE last fall that anyone other than my wife and I had been on the boat at the same time. We had 4 adults and 3 Grandchildren on the boat at some times , when not in the lake swimming. That , coupled with the fact that I have read EVERY anchor locker drain thread on this forum , but not got around to sealing the crappy drain plug on inside of anchor locker yet , had me prepared for more water onboard. It's just where I found it that has me confused ?? The boat sits on a lift , elevated , and covered when not in use. I have never put a level on the lift , but to the eye seems very close to level. I first opened the main drain plug. Outside below clean out plugs in bilge of boat. NOTHING. I had vacuumed this area and cleaned out the Yamaha factory hardware (screws , washers , etc.) when I first purchased the boat so I know it not to be blocked. I then moved to the engine compartment. Both plugs (pic 1) were closed over the weekend while boat was in use. No water anywhere in engine compartment or under bilge pump. So far so good ! I'm ecstatic. Then I move to the in floor storage compartment. Plug is in BUT contents are wet. I usually keep fenders , noodles , and other items not damaged by water in there so no big deal. Maybe a pint/quart of water total in the sealed locker. I vacuum it up and dry it with towels. As I open the plug , water starts shooting up like a water fountain. I grab my 3 gal. Ryobi wet vac and put the nozzle over hole. In about 2 minutes the tank is full and I dump and start again. I get about 2 more gallons. So between 4-5 gallons from under the ski locker ? Whats down there ? A trough . a tube . or just a void area of the hull ? I thought everything drained to the rear bilge ? How many other collection areas do these boats have that we haven't found yet ? YES , I did seal around the anchor locker drain with 5200 after cleaning up the in floor locker.
