Utopia Fuel Gauge
Jrfiero
SeaDoo
I have a new-to-me 2007 Utopia 205 SE, twin Rotax. The fuel gauge doesn't work and I haven't yet done any troubleshooting.
But, there are two fuel pump assemblies in the tank with similar wires, not all connected. Does anyone know if each fuel pump assembly has a sending unit? In other words, can I just switch the wires to the other pump assembly to see it that works?
I'd just go do it, but the boat is in the shop (where it's been mostly since I bought it) so I can't try it right now. The wiring diagram I bought is also with the boat. Getting ready for when it comes back.
Thanks,
Jonas
what do you mean by "not all connected?"
according to the fiche, each pump has it's own sensor unit attached. according to the PWC 4-Tec wiring diagram (one unit), the signal is routed through the ECM/ECU before being displayed on the gauge. though it seems overkill to have two, I would assume the two signals are averaged before going to the dash. however, depending on the programming, I wonder if one failing causes a total failure? ...though that would seem to defeat the benefit of having two in the first place.
