Upgrade the look and ignition components on your Rotax
ScarabMike
Green Cove Springs, FL
Guys/Gals,
PWC performance is teaming up with BRP in releasing a kit that will upgrade some components to the ones in the new 300hp Ace motor. Looks like the kit will be around $350. I can tell you the ignition coils are a definite upgrade. Ill post a link to the kit when it gets released.
This kit contains the following original Sea Doo OEM components. All Plug and Play.
3 x Ignition Coils
3 x Coil Cap/Seal
3 x Coil Bolts
1 x Valve Cover
1 x Oil Fill Cap
1 x Oil Cap Pin
1 x Oil Cap Band
1 x Oil Pump Housing
Here are some pics of the components. 300 Valve Cover.jpg image (1).jpg image.jpg
Hhmm! Kinda digg'in the look... Curious if you get anymore HP too!
As long as you are not having issues with spark blowout, coil upgrades will not net a performance advantage.
That head cover looks really sweet!!! Agree with ScarabMike regarding the Rotax engine plastic cover.
Love the custom made exhaust header system from the picture, I'll run that thing straight through the transom.
Where did you get that beautiful exhaust manifold?
