Jim_in_Delaware
- Southeastern DE
- Boatless
- NA
- Other
- Other
Folks, when towing, often run out of payload capacity before they reach towing capacity.
I would assume that with two kids, the OP has a quad cab or crew cab. While there is a lot of good information in post #15, I would use the chart for the quad or crew cab in post #14. The difference between the charts in posts #14 and #15 would be a reduction is tow capacity of about 400 lbs but and increase in payload capacity of about 200 lbs.
As @FSH 210 Sport notes, there is still a decent margin in both tow/payload capacity no matter which table is used.
I would still suggest that you wait and try towing a 252 FSH with the existing truck. If you find it comfortable to tow - then great. Otherwise you start looking for a new truck.
Jim
Jim
