KC-AR240
- Kansas City Mo.
I even checked my drain out plugs to make sure they were both seated correctlyAll winter long, I had them on a noco maintainer. They are fully charged. Checked with my multimeter
I'm not an electrical person. The wire coming from the red knob(start battery) is running to the +. The other (negative) wire runs back to the motors. And then there's a very thin wire that says Negative on itI wonder if the switch has failed, are you able to direct connect the motor leads to the battery (remove the switch from the equation).
The other 2 batteries run everything else . Connext Turned on, speakers all turned onSo you have power to the other systems fed from the start battery but the starters will not turn the engines ?
So you can see voltages of house and start batteries…The other 2 batteries run everything else . Connext Turned on, speakers all turned on
Jiggled the throttle handles as I was attempting to start .. Nothing. Clean out hatch closed and plugs are in place and safety lanyard is in place. Connext says 12.4 volts and 12.8 voltsSimple things to check:
Next - what's the Connext system saying for battery voltage on your house and start? How old are the batteries? Even fully "maintained" batteries can die over the winter.
- Throttles in N? Jiggle back and forth to be sure.
- Safety lanyard in?
- Cleanout plug hatch closed and secure?
It dropped a tiny bit. 11.9 and then back upSo you can see voltages of house and start batteries…
What happens to start battery voltage when you turn key to start?
And just to be clear, both motor keys are giving you no response when turned to start. Motor is not cranking at all? Or cranking and not starting?Jiggled the throttle handles as I was attempting to start .. Nothing. Clean out hatch closed and plugs are in place and safety lanyard is in place. Connext says 12.4 volts and 12.8 volts
Correct. Neither engine will start. When attempting to start, the radio and blower motor go silent....... Just no engines turning over.And just to be clear, both motor keys are giving you no response when turned to start. Motor is not cranking at all? Or cranking and not starting?
Edit - go to your safety lanyard. Disconnect it, and then reconnect it. Just because it looks like it's in place, doesn't necessarily mean it's in the RIGHT place.
Only the starter in connected to the 1st batterySo you have power to the other systems fed from the start battery but the starters will not turn the engines ?
