Searched and couldn't find...a good tire pressure for our trailers
OCMD
Ocean City MD
I've seen up to 90 psi/ Really?
Look at the sidewall of the tire. Worst case the trailer tongue, but at your age of trailer, I'm sure the tires are not stock. You won't see that size tire ever over 50lbs.
But whatever it is rated for on the sidewall, run it within 5lbs of max pressure.
That is a long standing recommendation to maintain even wear. Good luck.
If you look on the inside of the tung of the trailer were the I'd plate is you will see the recommend tire pressure. It's like the plate on your truck or car with same info on the driversdoor jam. Usually it's yellow.
All the guys at big o and americas tire tell me to run the max pressure cold stated on the side wall of the tire unless the trailer says otherwise and your using the same size tire that came with the trailer.
one issue. The trailers, at least mine, came with bias ply tires. Most of us have switched over to radial tires ? Max on my good year endurance tires is 65 psi.
Something to keep in mind as well as the load in the tire ls how fast you will be towing. If you are going to be towing near the max speed rating you need to be at max cold inflation pressure.
Usually manufacturers have or can give you recommended inflation pressure for a given weight and load.
@biffdotorg recommendation is sound.
Okay just went and checked the Goodyear website and found this handy chart, inflation pressure based on load. Looks like the speed rating remains the same.
Only your sidewalls will tell you the pressure. Be sure to inflate to max when cold.
If you want to not worry about your tires, upgrade to GoodYear Endurance.
This is the way.
This is what you need if towing long distance. Its great to know whats going on no matter what the pressure needs to be. Trailer tires heat up from the sun and the air pressure on the sunny side is always about 8 10 lbs more plus they just go up from friction. My max is 50 I fill to 45 when cold, stock tires from 2018 shore lander
tire pressure monitoring
So I tried to call and talk to Goodyear.. waited on hold for 15 mins. Then called Discount tire where I bought the Endurance trailer tires and asked them, short answer, run the max psi on the trailer sidewall, this results in the lowest heart build up and least rolling reistance-you can see how those two go hand in hand. The guy at Discount also state that the max tire pressure cold on the sidewall is how trailer tires are designed to run.
Here’s a link to Goodyears tips page.
Thanks for the link…. It got me thinking, I need to get a TPMS set up that will work with my truck as it has the ability to look at / monitor trailer tire pressure.
The stock Carlisle bias ply14's are 50 PSI. We replaced them before the season with the Goodyear Endurance D rated which call for 65 PSI and have a higher speed rating, as shown in the chart @FSH 210 Sport posted above.
The stock Carlisle’s have a speed rating of 81, impressive really. But, my Carlisle’s got flat spots in them and were also out of round that never went away and vibrated like crazy…I could see the spare tire vibrating on the mount going down the highway.. Now with the Goodyear endurance they are as smooth as can be, spare doesn’t vibrate on the mount.
I still have the stock Carlisle spare though. Hopefully will never need that, going to try and wear some of the tread off of those Goodyears this summer!
We bought new wheels and tires, also replacing the spare. Going to put 2500 miles on them over the next 2 weeks.
Safe travels and tight lines!
