Scarab Radio / Sound System Wiring Diagram
JoeScarab
Scarab
HO Impulse
Does anyone know where I can find the wiring diagram for the sound system in a 2014 Scarab 195?
I think the Kicker Amps don’t have power but the rest of the boat, including all Accessories and horn, work fine.
The radio powers up and has audio at the pre-amp outputs, so it looks like the common denominator is power for the amps.
I’ve of course checked all fuses, replaced the two battery relays and the battery itself is strong and fully charged.
Thanks in advance!
Check the Breaker panel where battery shut off is located. Should be a 40 amp breaker labeled AMP.
Upon further troubleshooting I found the 40 amp breaker had some resistance build up and wasMy passing full voltage. I replaced it and we’re cranking the Christmas Carols! Thanks!
I’m having this problem too. We have ordered a 40a fuse so hopefully this does the trick.
Hello, I came across this and I have had issues with my stereo from day 1. I see the panel in the back by the power switch, how to I change or check them?
