Scarab 195
Bernie
Scarab
Bought a 2014 195 with 16 hours on it in May of 2016. By June of 2016 never took delivery of the boat and was told by dealer that the engine was no good so I told them I am making payments on a boat I don't have. So they took it back and put me in a new 2015 195 for the same money. I took the new boat out end of June 16 and when I turn steering wheel loud hearing noise. Dealer says bad bearing and crack in housing. August 2016 boat still at dealer waiting on new part. I would not recommend Scarab at all to anyone I know. Horrible boat for the money and brp doesn't back up there boats with parts availability.
Seems odd that you were makin payments on the 2014 before you took delivery . Did the dealer give any other info on the 2014 besides "engine was no good "?
The 2015 you took delivery without a sea trial ?
You need to get on the phone with Scarab warranty regarding the 2015. I would be right in someone's grill...:mad:
I know that its no fix to crappy service, but what parts are you actually waiting for? Maybe we can find the Seadoo equivalent, and get the boat in the water faster.
Marine Max had to give us a captain's orientation so when they got the boat from one of there other dealers it was 2 weeks until we could take delivery of it. A day before we took delivery I was called and told it wasn't running right and needed a throttle position sensor and it was on back order so 3 weeks later they put it in and the boat still didn't run right so that's how I made a payment before we took position. Then that's when the dealer got us the 2015 when I told them I was contacting an attorney.
All they told me is that it was the housing below the bearing in the propulsion system and when they looked it up it was NLA part. Then BRP called them and said it was redesigned, and that how it is left as of now.
Thats nuts @Bernie . I feel for you man. Please keep us posted on what happens. The more of these threads we have , the more ammunition our community has to force a change in their practices.
We did the sea trial and didn't hear the noise until we drive the boat for 10 hours and paid for the first service.
If the issue is the pump, then its an easy 2 hour (maybe faster) fix. The boat uses the standard 159mm pump thats available in the RX line of skis. I can probably get you all the pump information and part numbers. Tell them all these parts are readily available, and to get off their ass.
Numbers shown are quanties used per assembly. Prices are based on a quantity of one (Each). Order the quanties needed for repair.
ORDER
QTY REF.
NO. PART NO. PROPULSION SYSTEM - EXTERNAL
DESCRIPTION NORTH AMERICA (CU)-ENGINE 1503 HO ETC
31CA PWC's
PRICE EACH
1 205562560 SOCKET HEAD SCREW M6 X 25, SCOTCH GRIP 3 1.58
2 207362060 HEX. SCREW M6 X 20, SCOTCH GRIP 1 1.17
3 207383060 HEX. SCREW M8 X 30, SCOTCH GRIP 4 1.45
4 234061600 FLAT WASHER M6, STAINLESS 3 0.27
5 234081600 FLAT WASHER 8 MM, STAINLESS 4 0.43
6 250100104 ELASTIC FLANGED NUT M20 1 9.99
7 267000030 ANGLED BEARING 1 64.99
11 267000458 IMPELLER BOOT 1 11.99
14 267000372 WEAR RING 1 68.99
16 267000388 IMPELLER SHAFT 1 97.99
18 267000428 IMPELLER COVER 1 14.99
20 267000469 PLUG PLASTIC, BLACK 1 5.99
23 267000567 STAINLESS STEEL IMPELLER ASS'Y 1 329.99
24 267000540 IMPELLER HOUSING 1 319.99
26 XXX IMPELLER INSERT 1
30 267000663 VENTURI, BLACK (NLA - USE PARTS LIST BELOW) (SEE NOTE) 1
30.A 267000787 ...VENTURI, BLACK (MAY NOT BE SHOWN) 1 159.99
30.B 271001885 ...SIPHON TUBE (MAY NOT BE SHOWN) 1 1.99
33 271000785 WATER OUTLET 1 9.99
34 271001133 SIPHON TUBE 2 7.99
35 267000282 PLUG 1 13.99
36 271001393 SPACER 1 8.99
37 271001813 ANODE ZINC 1 12.99
45 293200086 OIL SEAL 1 40.99
46 293200087 NEOPRENE SEAL 1 13.99
47 293200089 OIL SEAL 1 18.99
49 293300013 O-RING 2 5.12
50 293300086 O-RING 2 5.99
51 293300090 O-RING 1 5.99
52 293300114 O-RING 1 12.99
53 293370038 CIRCLIP 1 9.99
NLA - THIS ITEM IS NO LONGER AVAILABLE AS AN ASSEMBLY.
Powered by HLSM
I have been on the phone with both boat issues and was told that's why they have a warranty to fix issues like this but in the meantime the boat just sits
That sucks I'm sorry to hear that . Hope you get some satisfaction from this mess and SOON !
ORDER
QTY REF.
31CA PWC's
PRICE EACH
Powered by HLSM
Mike I assume number 24 is the housing the dealer is talking about
Would you recommend keeping the boat when it is fixed or run from it? My family and I have lost the season dealing with the Scarab issues.
I'm sorry but call in the attorney if that is an option. This is either made up or worth standing up for. So this may be an easy fix, but what happens when it is a hard fix? Yes, you should run from a 2014, a 2015 is less scary although you do t want the one that is broken as their way of exchanging. I would look for a 2017 scarab or Newer(?) and not a new model. That or a well supported Yamaha, searay, moomba, doral, etc.
Sorry, feel bad for you
