Ribbon Delete 2018 AR195
jEt_jAk
Jetboaters Commander
SoCal
AR195
Finally got enough courage to do it. Lake tested today all good. About 100-200 higher RPM but max speed not changed much. Engine sounds deeper/throater. Maybe a bit better acceleration.
Installed a Fizzle/Tial BOV as well.
Was not an easy installation for me since I was am a novice but I did a lot of research so knew what to expect. Required fuel rail disconnect, wiring harness, manifold remove and ribbon drilled out. Used the Riva kit with hole saw. The blow off valve I tapped into the manifold. I am using a flame arrestor intake filter to still be USCG approved.
Is it worth it? For me yes, it’s not a huge difference but if you like to eek every bit of performance out than I would say yes.
62E0FCA3-BBF6-43A5-9275-39CE6A5A2200.jpeg0EB1366B-B706-4DA1-83F2-97987EB35E7A.jpeg3A2D3B08-39CE-4775-91EE-F5C237B515BB.jpeg61118AD0-E693-477B-A880-D37BF6A1FB9E.jpeg
I haven't been following the ribbon delete threads too closely but what is it supposed to do for you? Increase the top end/max speed? Or increase performance across the board? Thanks.
The ribbon slows down airflow. Removing the ribbon helps the engine breathe better. For you all with superchargers, it won't make a difference on the top end as the SC will ram the air in. But it will give you a little bit more power at lower rpms when the SC is barely spinning.
It's a no-brainer for the NA engines as it's a simpler operation and w/o an SC anything we can do to increase flow makes a difference.
