Acard7
Jetboaters Commander
- Iowa
- 252SE
Confirming this is the starboard pisser for the thermostat? Due to @Babin Farms and I mentioning the fact that we look at the pissers like psychos I found this one today not peeing while leaving the cove. Never got an overheat warning, and when we trailered it looked like it had a tiny bit of water reluctantly leaking out of it. I’m going to check the lines when I get home. Plan to run it on the hose tomorrow to maybe flush it and use some weed wacker line to clear what I can if that’s the issue. I have two thermostats on hand in case I need to replace.
