CaptRedbeard
- Omaha, NE
This info is for a 2006 MR1 110 non—HO motor from an AR210. I believe the oil pump might be slightly different on the HO motors. I searched high and low for this information (here, google, shop manual, etc) without luck. I wanted to make a quick post on this topic to help others that may be looking for it. Back story: I have a blown MR1 motor that I’m in the middle of rebuilding (I’ve detailed some of that here) and I wanted to drain the oil pan as much as possible before taking it apart. Here’s what I learned:
The oil drain plug requires a 13mm socket, is located on the back of the motor, just to the port side and below the driveshaft coupler. Here it is (not labeled with a number) on the parts diagram:
I didn’t measure exactly how much drained out of the pan, I would estimate about a quart. Here it is as I am draining it:
And here is a photo of what the bolt head looks like:
Hope this helps somebody out!
