JetCraft part numbers?
Arbor
Jetcraft
Hello all,
New-be here with some part number questions.
I have a 2007 jetcraft boat with a M1 Yamaha motor 7YMXM1.054GA
Most of the time its flooding number four cylinder with gas, but will fire off occasionally when warmed up.
Gas getting in the oil of course.
I've ordered one injector that I hope to install it soon and changed the oil in the meanwhile.
After reading all of the comments here is seems that I may as well steel myself into getting a ECU electrical unit as well. ( I'll ohm the 'bad' unit looking for a short, if none I may forgo the ECU )
My question is what's the right part number?
I've been using the boat AR230 HO as a lookup because it is closest to the engine above, while this works for
air cleaners and injectors, I'm a little uneasy ordering the ECU.
AR230 HO (STX1100CF) = 6P6-8591A-01-00 (new part number) old part number = 6P6-8591A-00-00
WaveRunner FX HO (FX1100F) = 6B6-8591A-20-00
Both Yamahapartsnation and Yamahasportplaza do not list a Jetcraft boat as possible choices
I've posted this is the wrong place 1st, Admin will you please clean up after me? I hate computers.
Thanks in advance,
Arbor
Is there a part number on your existing ECU?
Have not removed the ECU unit yet, but was of thought that if it has a number, it will not be anywhere close. As in the air cleaner, part number and the number stamped upon the air cleaners case are not even in the same family. However, will not give up hope just yet.
OK, ordering the part number 6P6-8591A-01-00 from sportplaza and just have to cross my fingers in hopes that this will work out. The original one had water in it's case ( I'm the new owner thus don't know just how that happened ) so I dried it out and reinstalled, tested it to no avail.
The new one should be here in a week or so. In the meanwhile I'll be dry docked for the opening of fishing, rats.
New unit came in, installed it yesterday, tested today. All seems to be operational. Just have to wonder how water gets into that plastic coffin. I did notice that the screw holes are open on the top of the unit, perhaps seeping in over time? In addition I made a cover to place over the top of the pump clean-out port to deflect water if it should start to leak. After returning from the test run found every thing to be dry and water free.
In hopes of having a blissful boating summer.
