Setec_Fl
I was doing my pre season check out and the starboard motor showed it was over a quart low of oil, so I topped it off. Greased everything and finished the rest of the checkout. Hooked up the water line, started the engine, and turned on the water.
about 3 to 4 mins later, the exhaust started blowing smoke and oil.
I hurried up and shut off the water and then the engine. Rechecked the oil and it showed it was over 2 quarts above full!
I pulled the air filter and there is oil in the filter
I pulled the plugs and there is oil on the plug tips and I can see oil on the piston heads.
now I can’t even get the engine to crank over with the plugs out.
I can’t find a video on how to hand crank it.
What do I do?? Did I screw my engine?? Please help. Hoping I didn’t vapor lock the engine by shutting it off so fast but I don’t know what else to even try.
