FSH 210
rpenrod
Question about the fsh 210 sport. The drain in the bow just above the water line. What does that connect to. I thought it was the anchor. When driving at low speed and people riding up front water is being driven up that drain hole. The water is then pouring into the locker in the floor. The boat seems to be running front heave and sits bow down in the water when nobody is on the boat. It's almost like I have water trapped in the nose somewhere. Is anyone else having this issue. Solutions?!? Thank you!
Common issue and a few options for fixing:
1) Use the factory drain and reseal on the inside of the anchor locker to attempt to prevent the water from coming in between the outer hull and anchor locker.
2) Buy a new drain that has a longer internal stem and allows for more sealant.
3) Plug the drain hole completely with silicone. This is what I did as I rarely use my anchor.
See my post #118 in this thread for a fix.
