FSH 190 Connext
dieseldavis23
So I just purchased a 2019 FSH 190 . Noticed while on the test run the Connext screen would not respond to touch . The dealer installed the screen but didn’t program anything . I didn’t fire the boat up again before leaving ( maybe a mistake) . Got it home and fired it off and got a shut down engine see dealer alert . I will also say I forgot to attach the lanyard and spun it several times before realizing it. Got the lanyard attached and it fired right up but the see dealer warning came up . Do these monitors have to be programmed or are they plug and play ? Is there a way to check codes in the Connext monitor ?
