Exhaust smoke/steam - more than usual
Ribs77
PNW
So there's always some steam/exhaust that I see when surfing, I know it's not a big deal, but today it seemed like there was kind of a lot more than usual.
The boat performed fine, I didn't get any temp alarms, pissers were pissing, etc... But it was a LOT, especially on the starboard side and especially toward the start of the session.
Any reason to be concerned? I ran the boat for probably 10 mins going from the wet slip to the end of the no wake zone, then killed engine and spent 10 mins setting up ballast before getting started.
Could the engine have completely cooled down in that time and then been under stress /burning oil or something? I changed oil before the start of the season and have put about 50-60 hours on since then.
Pic
Bonus pic of the rad wake that I have dialed
Smoke usually means burning of oil, maybe check dipstick to see if you are low.
Thats a great wave! Can you share your ballast/setup?
That looks like steam…. If the water temp has cooled down and or the air temp has cooled down as well. If you’re oil level is good and no alarms its normal.
