Depth finder issues
mraz72
Jetboaters Commander
Rochester, NY
242X E-Series
Just started having an issue with my depth finder which displays in connext. A typical trip lately would be
1. start from my wet slip, depth gauge working properly
2. a short time after driving around, the depth will freeze at the current depth, and then start blinking with the depth not changing, even though it definitely should be
3. The blinking will continue for the rest of the trip, with small periods of the gauge working, but that is short lived as the blinking starts again
4. seems to repeat this behavior with the next trip
turning off the power to connext for a short time doesn't seem to fix the issue, seems like the time in between outings has the depth working for a short time.
I do wet slip, which has me thinking there is some growth obstructing the depth probe?
Ive been having the same issue...looking forward to any insight
I'm thinking of adding a GPS type device just to get the depth, maybe I should call the dealer and see if they have an insight.
I've seen this too, keep mine on a lift. I have a garmin for backup
Factory one just started last week would work in shallow areas then freeze up frequently..I trailer so no visible grime or damage to transducer. i'll start researching add ons.
If your not under warranty they are made by airmar. I'm waiting to see if someone changes it what model is used . Mine works and it reads down to 1ft the older versions cut out at 2.5 ft
I have a similar issue. Works normal, then I get flashing gray bars, with no number readout.
Today, I was in 120 feet of water, and got the Low Depth Alarm, which is set at 4 feet.
Been this way since day one.
Same issue here.
I had this same issue on my second outing of a brand spanking new boat. Trailered and new so doubt it was an obstruction. I thought maybe the lake was too deep to register. Hasn't happened since then though and ive been back on that lake in the same spots and its not a depth issue. Weird. Will watch this thread for possible answers to this quirky problem.
does the AR195 use the same type ? Not that we even know what airmar model is used for the 242X series I think its the P19 series and they have a few different types in that series
Happens to me intermittently too. For some reason it’s more common when idling in neutral and will start to register correctly again when starting to move.
I have been experiencing the same issues. Dealership replaced transducer under warranty. Haven’t been to the lake to verify replacement fixes the issue.
Never had problem before, but on Sundays trip the depth finder was erratic. Has anyone changed their sensor or found other solution?
Mine is erratic as well- has been since new, however, it starts working correctly after driving a bit and often works correctly. It's so hit or miss I don't think a tech could isolate the problem.
HI All,
has anyone figured out what AIRmar model is used by Yamaha? $600 for OEM is rediculous. thanks!
maybe try to contact air mar directly and mail it to them could even be covered by there warranty
my boat came with a plug to fill the airmar hole . They recommend removing for winterization, oh bad word this time of the year it could probbaly get freeze damage from residual water in the bilge keep us posted
Mine has always been hit/miss. Lately it's been reading several HUNDREDS of feet deep while I'm still in the creek leading out to the lake by us - there is no place that is deeper than 4 feet there, I've been coming to the area since I was five years old, and I am beyond familiar with the depths.
I'm wondering if there's some other depth finder that could somehow be hooked into the Connext screen. I'm not opposed to having another display at the helm as long as it works, but it'd be nice to be able to tie it into the system.
It seems to me that even if these things are covered by warranty, enough people have problems with these that I wouldn't want a replacement, since they'll end up being just as unreliable. Why swap out crap, simply because it'll be new crap? It seems clear to me that it'll eventually end up the same as the old one.
I think I still have my plug, but I wonder what's involved with removing it from the system, or even if it CAN be removed. This isn't a vital fix for me, so there's no way I'm addressing this before the other things I want to do with the boat, but if I eventually take my boat to another lake, it'd be nice to know that I'm working with more-reliable depth info than what the OEM gives.
Its not that common of a failure otherwise more people would post about it and know what the replacement is especially at the expense that they are posting . Any electronic item exposed to water will have a failure rate one flaw in the casting and the moisture gives it problems . My 2005 worked until it was sold 13 years later while others had failures not a huge amount but a few. Im not sure what model years these were used but definitely from 2016 . Mine works but just wanted to give info on what worked in the past
Seems to be the newer models that are commented on most often here. I'm thinking your older model worked fine and the new "improvements" messed up a perfectly fine item, either with a crap part or bad placement or both, or even something else.
It's much like the improvement of the cleanout tray drain tube that was eliminated in someone's new 19' but they didn't trot this out across the whole line.
