CAN Communication error on 2019 AR195.
Doogie55
The connext screen says transducer:CAN, communication:NOK. Does NOK mean Not OK? I wonder if I need to replace the transducer because the speed and tach is in error. The depth and water temperature is OK. I've checked all wiring connections, new batteries, fuses, and paddle wheel. There are no errors or error codes for engine inputs or outputs. Engine runs fine just no speedometer or tach which I assume is why the no wake and cruise also don't work. Boat has 70 hrs and is a 2019.
