FattyMatty
- 195S
So question. I am putting the dual battery switch in my 195s. I have a wire labeled battery switch, bilge, C, and one unmarked that goes to the engine I believe. Currently I have the “C” wire that comes from battery one to the battery one post on the switch along with the bilge and the one red wire that goes to the engine. Battery two post will have positive from battery 2. The output is where I currently have the wire labeled battery switch. And that wire runs into a harness and fuse I believe. Does this sound correct as far as wiring goes so far? I want to put another red line out for positive from the output post to run to a bus bar.
