ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
We put a new battery in checked fuses. Could not get clean out plug out ( jammed in and stuck) Boat ran fine all day then would not recognize the turn of the key. Prior to this the radio stopped working the week before. Joel
Did you check your kill switch lanyard and insure it is seated, try pulling it out and reseating. Also make sure on the new battery install all the connections are solid and tight, check the selector switch if you have one. For the clean out I read here on the forums that you can try filling the hole on top of the plug with ice let is set for an hour or so.... @Eric Popper suggested this and it worked. Also insure the stern hatch is down there is a kill switch back there.
Check the cleanout hatch, safety switch. You can hold this down while someone tries to start the engine. It wouldn’t be the lanyard safety since the starter would still engage but the engine just wouldn’t fire up.
It could also be a main fuse. I’m not familiar with that model. Check owners manual
