255xe 255xd owners please take some measurements for me
Wicked92
255XD
Im chasing down a steering issue with my boat, steering was crooked from the factory, it was supposed to be correct by the dealership. I still dont think the Surfpointe is set to spec. Ive taken my measurements as the boat sits current. Can you measure with the steering wheel straight/keel straight (start boat, center steering wheel, shut boat off, verify keel in straight) the cable length to the centerline of the clevis. Port for me is 11.5" Starboard is 12 1/8. This is flush against the pump plate. Picture provided. Can you also go in the compartment under the front starboard seat in the white box you will see the steering cables and where they attach to the hydraulics. Are they even? Pictures of mine provided....can you do same on yours? Curious as to where everyones boat falls. Ive seen Surfpointe on 242x's and they were more drastic with the canted in.
wheres all our 2255 xe xd owners at...help a brother out :)
Just picked up my 255XD from dealer. It is still on the trailer. Do you still need measurements?
Just a brother trying to help you out..
if you can get them sure, it helps all of us in the long run.
Also may even help you out if we need to make sure your boat is correct. Ive been thru my boat every which way to sunday so dont be shy to ask me anything.
Get you steering wheel straight, start an engine real quick center it then shut off.
Measure the cable to pump nozzle bolt centerline from the back of the pump plate bolted to the boat for both sides.
I currently have mine set to 11.3 (port) and 12.3 (starboard) which is essentially 1/2 less and more compared to nozzles straight at 11.8" This was based on measuring a 2019 and 2020 242x at my dealer.
Also if you could take a picture of thread engagement on the steering ram under the starboard bow seat. Remove the white lid cover. Curious as the setting with straight wheel.
Thanks bud. Enjoy your boat!....go thru it with a fine tooth comb, be interesting to see how yours turned out. We believe mine was a stop work, due to missing parts, got sidelined, then brought back in later months.
Here is the starboard jet nozzle. 2021 255 xd
Here is the port jet pump.
I am leshock brother and chief mechanic and head wine drinker.
We r installing cobra fins right now. We also had misguided jet nozzles brand new from factory and will post a thread on this issue later today. Easy fix imo by adjusting nozzles and rudder.
so you corrected it to these measurements or this was how you got it?
your port is "surfpointe" setting maybe even more aggressive.
I think mine were out the same as this. Yup just checked my pictures. Port canted in...starboard straight. LOL yammy QC on point!
The prior pics were of the boat straight from the factory. At dead center steering wheel the boat on plane would drift to port, as you would expect looking at the nozzles. In order to go straight at planing speed, dead center on the steering wheel was at 1 o'clock position. We adjusted the steering tie-rods at the pump nozzle, and the tie-rod to rudder, when we installed our CobraJet steering fins today. I will go and take another set of measurements now that we have made the adjustments.
The prior pics were of the boat straight from the factory. At dead center steering wheel the boat on plane would drift to port, as you would expect looking at the nozzles. In order to go straight at planing speed, dead center on the steering wheel was at 1 o'clock position. We adjusted the street control tie-rods at the pump nozzle, and tie-road to rudder, when we installed our CobraJet steering fins today. I will go and take another set of measurements now that we have made the adjustments.
well the cobras want you straight so im going to guess 11.8 inches. I wanted a factory surfpointe measurement. But yours were fucked up like mine lol
