255XD Shorelandr trailer advice/questions…
Howdy Pilgrim
255XD
I’m having issues with my Shorelandr trailer that came new with my 2022 255XD.
I already went through 4 brand new tires after one of them became almost completely bald on the outside tread. I hate to say it but I’ve trailered the boat less than 15 times. Maybe 1k-2k miles total
I called my Yamaha shop I purchased the boat from and went through the process of trying to warranty the tires. Took the trailer to an alignment shop, everything checked out perfect and within spec. They gave me all the measurements and good to go.
Noticed after last time to the lake that the boat just continues to feel like I’m dragging it at times. I have attached photos and it appears that the brakes are engaging and potentially staying engaged on the passenger side of trailer (starboard of boat). You can clearly see the wear between the two sides are not equal at all. Img 6671 is port side img 6672 is starboard side and much much more scored and deeper. This is the side where I had issues with the tire as well
Questions/Advice…
1. What could be causing this to happen
2. What are the replacement parts for rotors and pads? Trailer model YAV51TJXWMS0-16
3. Is it normal for them to brake down this quickly or how often do you change your brakes?
Any help is SUPER appreciated as we have a trip coming up that I have to drive 4 hours each way and just want to try and make it safe
Here’s a thread that I did on the trailer bearings and brake maintenance that may help.
Have you been checking the hub temperatures when you tow?
Have you jacked the wheels up and checked for excessive drag?
Typically if a caliper hangs up in its travel the results are dramatic.
I have not checked the hub temps. What would those normally be and how are you recording the temps? I guess I would be looking to see a difference between the too and maybe a temp gun?
I have not jacked up the boat and spun the wheels myself. I was told that was done at the alignment facility because the whole boat/trailer has to be lifted but it would be good to double check myself for sure.
Thank you for the link I will dive in and if the parts are in there I will get those coming asap while I continue to diagnose 😎
You should be able to put your hand on the hubs without getting burned… the brake hubs will always be warmer than the non brake hubs.
Good job on getting the alignment checked.
Did a quick glance through your thread and one thing I didn’t catch was the rotors… are those a standard size or something I can measure and go from there? I apologize for my ignorance didn’t think I’d be messing with these this low of miles lol
You don’t need to start throwing parts at this project until you determine what’s wrong. You need to pull the wheels off and go through everything. One tire wearing on the outside edge is weird do you have any pictures?
Here’s a few more threads to look at. In that first one is a couple pictures showing how to push the caliper over with a pry bar, then how to manually pump the surge brake actuator. Do one wheel at a time. Check brake fluid before you begin.
Are you in salt or fresh water?
Did you check your owners manual for the trailer that came with the boat?
In that first thread I sent you it shows the slider pins, you may need to pull those and make sure they’re lubricated and that the calipers slide freely with the piston collapsed and the tension spring removed.
The pics you included in your first post don’t look that bad, there’s a difference for sure but that could be air in the brake line between the starboard side and the port side.
Thank you so much for this information and the resources! I will definitely go through the list one by one and run this down.
Here’s a pic of the tires. The top is the side I seem to be having problems with while the bottom is the driver side of truck port side of boat. Less than 3k miles easily.
Caliper pistons will also lock up. Mine did and the brakes were always dragging.
I'd compress them and be fine for a day.
They get stuck.
Got the wheels off the ground and did some testing. Tires spin freely… maybe a bit of slight drag as I you can hear it but tires will spin 2-3 rotations on one hard spin with the hand
Checked brake fluid, all good there. Manually tested the surge brakes by using a screwdriver and actuating the surge brakes. Both sides work and lock up the wheels as designed
HOWEVER… and I’m not sure if it’s supposed to operate this way, there were times during testing that the pin would get stuck back thus keeping the brakes on even when the surge brakes were not being actuated by the screwdriver, the pin was stuck thus brakes were on. We would hit that metal lip and it would then release the pin. This was occurring during testing so I don’t know if this could be occurring during normal driving conditions (see video)
Any additional advice would be massively appreciated as otherwise it seems the system is operating as it should
The pin getting held in position is part of the emergency break away function, so it’s normal. On your surge brake trailer if it breaks away from the tow vehicle, the cable will pull the trailer brakes on by compressing the actuator and the break away mechanism will hold the brakes on until that tab is pushed to release the brakes.
Ahhhh that makes total sense thank you!
Maybe need to look at rebuilding the caliber? The wear on these just seem like something’s going on especially with going through tires after less than 5k miles easily
I think there is something else going on.. if the caliper was dragging that much the rotor would be blue.
Did you bleed the brakes? If not do that as well.. get any air in the system out. This is a tedious process, get your friend to help you, and get a good amount of brake fluid… you will need a fair amount to flush the system and get the air out.
