210 FSH Battery Options
MrBubbaGump
I have flipped through the forum numerous times reading all the battery posts, and have a general idea based on my previous experiences with my last boat, what I have learned here and what I have had so far with this boat. So I am more writing this as a pros / cons debate to throw out there.
Currently I have the stock start battery (Not concerned at this point) and my stock house battery (DieHard Silver 24M 50AH)
Just for those that may ask I run my stereo at about 75% Volume and its a 1100W System. With this said I will run this somewhere between 6-8 hours with no issues / hasn't died yet. I recently added an 1100W Power inverter to blow up my floats, I use an high volume inflator that draws 750W which I use about 6 minutes to blow up the main float. All was well all day ran stereo right at 6 hours and got about 3 minutes into deflating with said inflator pump and the power inverter kicked off due to lack of power. Radio and everything else still worked fine just started running low on juice. So now I am on my quest to upgrade the battery.
Solution 1: (Easiest) Drop in X2Power 24M 76AH AGM Deep Cycle (57.7 pounds)
Pros - Easy, more amp hours, had before lasted a long time
Cons - Not Cheap, only 26 AH more than current setup
Solution 2: (Cheapest) Add another cheap DieHard battery in parallel
Pros - 100 AH, Cheap
Cons - Cheap battery, longevity? do you really get as much use as 1 X2 battery?, Weight! (83 pounds)
Solution 3: (Most Expensive) Raise mounting floor Drop in X2Power 31M 100AH Deep Cycle
Pros 100 AH, 1 battery, less weight than 2 battery's (75 pounds)
Cons - Expensive, have to raise the floor
lithium batteries?
I ended up not doing any of those options and ended up keeping both batteries that came with the boat. I added a 3rd battery a XS power XP3000 that is not connected to anything in the boat other than the AMPs for the sound system. I have an onboard charger that I plug in at the end of a trip to recharge since it is not connected to the boats charging system. It has seems to have enough power to run the radio all day no concern. I even did a trip that was a 4 hour round trip ride and about 4-5 hours at the sand bar and the radio was still pumping. I will eventually get a new house battery probably the x2power 24M since I did a toll on the current house battery before I got this new one for the system. IMG_2801.jpg
I ended up not doing any of those options and ended up keeping both batteries that came with the boat. I added a 3rd battery a XS power XP3000 that is not connected to anything in the boat other than the AMPs for the sound system. I have an onboard charger that I plug in at the end of a trip to recharge since it is not connected to the boats charging system. It has seems to have enough power to run the radio all day no concern. I even did a trip that was a 4 hour round trip ride and about 4-5 hours at the sand bar and the radio was still pumping. I will eventually get a new house battery probably the x2power 24M since I did a toll on the current house battery before I got this new one for the system. View attachment 207609
I am getting ready to do this exact project. One question. Is there anything under where you added your third battery? How did you attach your battery tray to the floor?
Yes I used a piece of star board to make the floor all one level. Screwed it into the floor and then screwed the battery trays to it. As you may have noticed the boat has the trays sunken and that only allows for two batteries.
I mean when you drilled into the floor for the 3rd battery is there anything under there I need to worry about drilling into?
I did something similar but I used cutting board material, I did not find anything under the top of the battery area, thought maybe I’d hit foam but not the case. The material is not very thick, so put your drill bit as deep in the chuck as it will go and just drill enough to get through the material. Then measure and use the shortest screws you can, you want to have at least 1.5 times the diameter of your screw of length beyond the material that you drilled into once the “board” is tightened down, the screw will barely protrude on the back side.
Another way to look at it is this, that area is completely encapsulated in fiberglass as in there is no way to get into that area, none of the boat systems will pass through there as there is no way to service them. And, the oem battery straps have screws in the bottom of the battery tray.
Thanks 210 for replying, I have been out of the country for the last few weeks. Exactly as 210 sport stated I did not find anything underneath as long as you aren't using 4 inch screws you should be all set there's nothing that I know of under there to worry about other than the bottom side of the boat.
I was just looking at this picture again, now that is a BATTERY compartment!
Do you need to leave that hatch open when charging to let the heat out? I’m pretty sure I’m going to upgrade and move my start and house charger from the head compartment to the battery compartment like you have.
Not sure that I have too but I do I almost always do though, if there is poor weather out I leave the hatch open with the boat cover on though.
Thanks!
I usually have my over the whole boat cover on and leave the head compartment door open as that is where all my chargers are now, three Victron IP 67 chargers for the trolling motor bank and the two bank MinnKota for the start and house battery. All the modern smart chargers will decrease output if they get too hot.
