2019 scarab 215 g wear ring questions
Kapem
Scarab
215 G
New member here, what size wear ring is used for a 2019 scarab 215 g. I couldn’t find anything specific to the 215’s.
epc.brp.com to check Rotax parts in the future. Get your engine model number and you can drill down in the Rotax JPS parts.
Twin 150HP require a 155mm wear ring, BRP#0460661 or Sea-Doo#267000419.
Those two parts should be identical. I recently purchased the same one for myself as a spare. But I haven't installed it.
Those part numbers bring up a 150 mm ring. Just an FYI. I was able to find 155 mm rings , so all is good
How do you determine what model you have? I looked inside the boat and see "Model SB" and on the engine has 6 numbers followed by "AAA".
6 numbers followed by AAA is your model number. The AA refers to the year. AA is 2014 like yours. I think it's the first two letters of the three, but don't quote me on that since I also have a AAA. So when you select Rotax JPS in the pull down, then you have to select the two letters that match yours.
