dalcini
- Utica, Michigan
- 242X E-Series
Prepping my boat for a marina slip this summer. I did a test today and confirmed that:
A.) I have no (factory) bilge without leaving House Battery switch ON
B.) Start Battery switch must also be on or the "low batt" alarm will continue indefinitely
So it seems that I'll need to leave all power off while away. With the battery switches off, I'll need to install an Aux Bilge connected directly to the house battery for peace of mind.
A few notes about my test:
A couple of questions for you all:
1.) Should I mount it as low as possible, or give it some space so it's not going all the time?
2.) Am I crazy to go ahead and take the boat to the marina before doing this install? (my guess is Yes) I will probably get to it in a month or so.
[edit]
3.) Any pump recommendations?
Thanks in advance for your thoughts.
- My bilge behavior is consistent with my 2018 240/2 owner's manual (see excerpt below). However it seems to be different on newer models per a 2023 post by @FSH 210 Sport. It sounds like the newer boats have the bilge wired directly to the House battery which can be better for moored boats.
- I will probably try to mount an aux bilge pump in the rear bilge (under the cleanout hatch) and wire it directly to the House batt. This seemed like a good suggestion from @swatski here.
[edit]
