ks9mm
- North NJ
- SX
HI All,
I have a problem I am trying to solve with a somewhat limited budget. I can't hear music while underway on SX240. I am not audiophile or need anything crazy.. With wife and kids onboard.. I just don't see any half naked women partying on my boat anytime soon. So i dont need a lot. Just something that sounds reasonable and reliable. and I want LED for some reason.. donno why. What I am thinking is following..
My plan is to wire it to the OEM head unit using RCA pre-amp..
My main question is.. Can I wire 6 speakers as described below and will this AMP be sufficient? Would I be able to use the Context main control to vary volume of mid cabins vs other speakers via Fade control? What would you do differently? Any other AMP that's comparable or better but at similar cost? I think it Must be class D, i dont want to run cray thick power wires or add another battery.
I did consider 6 Channel AMP but I do want to be able to adjust volume independent between mid cabin and all other speakers on the fly. and one again.. please keep cost in mind when suggesting options!
thanks for your help!
- 6 New speakers.
- 4 to replace Existing speakers
- 2 new to be installed above and behind Captain and passenger chairs. (I've see posts where it's show as a reasonable install location.)
- I am thinking Kicker speakers.. JL is just too much $$ and kicker seems to be the best value...
- JL Audio MX280/4 AMP
- Kicker LED controller
- Can I wire 2 Mid Cabins separately
- and 2 Bow and 2 Rear cockpit speakers in parallel on the other channel?
