ISLAND JAY has your Jetboaters.net Clothing, hats, stickers and more all at a 30% discount until June.
Click Here for more information>SWAG for JetBoaters.net members only
Is Yamaha doing anything? I have just hit 100 hours on my SX192, 2015 and am the 2nd owner. Should I be worried about the timing chain issues I am hearing about on this forum?
You’ll get different answers.
yes, it IS a known issue. And there is no simple fix.
only Yamaha knows the real numbers.
the odds of TC failure are still fairly small I believe those are, basically, on par with odds of other possible modes of catastrophic failure
that is just my opinion though, based on reading these forums and talking to people I know here.
Ive had more issues with my 2016 AR240 than most, still I consider Yamaha jet boats to be mechanically superior to most boat brands.
beyond that, I would always carry good boat tow insurance when in big/open waters. But I wouldn’t lose any sleep over it, personally.
Unfortunately, you only have three options and none are an ideal solution.
1) Upgrade the engine to the newer components. Someone put together a list of the parts needed on one of these threads and I think it was in the $2k range (somebody please correct me if I am off), plus the install cost which requires pulling the crankshaft, unless you can do that kind of work yourself.
2) Sell the boat. Maybe this is a good reason to make that upgrade.
3) Live with it and hope for the best. I believe the estimate is that this is affecting like 1% of the 1.8l engines between 2014-2016. It's pretty much bullshit that Yamaha has swept this under the rug. If these were auto engines I am guessing they would have been forced to do a recall. Considering the number of engines that are out there, 1% is a large number, but the odds that you will have a failure is still quite small. Unfortunately if it does happen it sound like a total pain in the ass and months of down time to get the engine replaced.
Yes, there is a kit available from greenhulk and possibly other places, not clear to me how it would affect warranty (a 2015 could still be under YES), and TC is not the only thing that can break.
not a lot of folks seem to be going that route but maybe it’s worth the peace of mind?
2014 AR192 here. I pull the valve cover and inspect at the end of every season. Bump the key to turn the motor, inspect the links, and repeat until i've inspected all the links. I have checked at 100 hours and I checked at 160 hours. I never replaced the valve cover gasket and it hasn't leaked. I hope to break 200 hours this season and then i'll check again in the Fall. If the chain does go, I will rebuild it with 2016+ components and keep the boat for another 200 hours. I'm taking this boat with me a long time because it fits my needs.
I have a 2015 192 with 145hrs and its been a great boat the YES warranty runs out in march of this year, even though it does seem rare that a chain breaks it will always be in the back of my mind this summer with no warranty. Im in the same “boat” literally, like said above theres three options, upgrade chains, trade it, or run the heck out of it and hope for the best.
Just run it and periodically check the chain like I listed above. Some people have found fractures in the link before failure. So checking will give you peace of mind during the summer. Ive heard about people with 400 hours on their original motor.
Same as any other 4 cylinder engine. Remove engine cover, ignition coils, breather hose to head, I think one electrical connector that gets in the way, maybe 12x 10mm bolts and the valve cover comes off. That doesn't reveal the entire chain, but the motor can be rotated by bumping the key to start. Bump, inspect, bump, inspect, etc. I mark the chain with a marker so I know when I made the entire revolution. To install the valve cover, there is a plastic guide in the valve cover that needs a little silicone to hold it in place. Reuse the valve cover gasket and put a dab of fresh silicone at the corners like the OEM had it.
If this doesnt make sense, then you can ask some friends if they can show you.
