2008 232 - Aux Power is Limited
IN2H2O
Limited
Hi fellow yamanerds,
I recently sold my LS2000 and purchased a 2008 232 limited and took it out for the first time yesterday. I have an odd issue where only some of the axillary power switches are working. Once toggled on the backlights all rocker switches light up but this is the list of what is actually working
Working
Aux cabin cup holder lighting
Bilge
The 3 lights (check engine, over heat, oil pressure) under the tachometer on Port
Not Working
Blower
Radio
Nav Lights
Rear shower pump
The 3 lights (check engine, over heat, oil pressure) under the tachometer on Starboard
I've check the 2 fuse's by the battery and each individual trip reset under the rocker switches. I'm not sure what else to try. Any ideas where to start diagnosing? The seller did confirm the radio and nav lights worked. Also is the VSR a OEM item?
Yes that VSR is OEM.
I believe the tachs are connected together so that one is odd. My shower stopped working once and the fuse by the battery was the culprit but I think everything else worked (I never use the lights though). There are fuses in the back wall behind both engines but I don’t believe those are related to the items you’re having issues with.
It does seem fuse-related but have you checked to make sure all battery cables are connected? There are multiple. I would check for power behind the helm and go from there after ensuring all battery connections were connected.
Just to confirm once the radio has power the head unit should turn on and no additional buttons need to be pressed?
Yup, flip on house power at the VSR and the rocker switch in the dash and the head unit lights up. You do have to push "Source" in the head unit to get it to do something but yeah it has power at that point and scrolling through the demo mode.
