CaptRedbeard
- Omaha, NE
Hey all. New to me 2006 AR210 and I’m refurbishing the trailer. I’m new to surge brake systems. Actuator is a UPF A-70 which is an older model A-75 from what I understand.
When I bought the boat, the trailer had a snapped brake line and a frozen actuator shock. Got those fixed and everything reinstalled now I'm attempting to bleed the brakes using the “tube and water bottle filled partially with brake fluid” method. No air or fluid coming of the (open) bleeder screw. Bleeder screw is clean and not rusted or clogged.
I disconnect and take the actuator back out of the tongue and attempt to get some brake fluid pumping out of the master cylinder but nothing. I disconnect the reverse solenoid to see if it’s clogged, but still nothing pumping out of the master cylinder. Air passes through the solenoid freely so I think that’s good.
I assume a functioning master cylinder would squirt brake fluid when pumped even if disconnected from brake lines, correct? At this point, next step is to replace the master cylinder, right?
Thanks for the help!
