84rzv500r
- Lower Keys MM29
well two things... what is the compression on the cylinders? pull the pump and inspect. if the engine is running with a free wheeling pump and not without more throttle with load on the pump in water at idle would tell me that its very low on compression (more throttle = more power to overcome the load on the pump..) My experience is that no load RPM (i run mine at 1800 RPM idle) and idle in the water with load on the pumps is the same...
