cwoav8r
- Naples, Florida
Changed the port side shift cable today, took one hour start to finish. Tried a new idea for pulling the cable through and it worked perfectly!
It took seven tools, and I didn't even have to open the swim platform hatch:
Crescent Wrench
Channel Lock Pliers
#2 Phillips Screwdriver
5/16 Combination Wrench
Needle Nose Pliers
Heat Gun
Jetboaters.net
Parts:
https://jetboaters.net/threads/teleflex-reverse-gate-part-number.3033/#post-61462
I'll leave out some of the parts that we already know how to do from previous posts...
https://jetboaters.net/threads/how-to-replace-reverse-gate-cable.28/
Used the crescent wrench holding it at a 45 deg angle to remove the nylon nut on the thru hull fitting. It only took a turn and a half then it came off by hand. Installed it back the same way:
Transom side disassembled and ready to pull... counted the turns when removing the cable end fitting, mine was 16 turns:
Binnacle out, three screws to separate the halves, one on either side at the top and one on the bottom... don't loose this nut!
Two more screws at the bottom to remove the plastic cover (pic didn't come out)
Wow! I didn't know my boat came with free spare parts! I'll remove that and save it for later...
Remove the nylon end from the shift cable. No need to count turns here... it was turned all the way on. Remember the jam nut when you put it back together.
An indication of how stiff the shift cable was... it was so hard to move that it bent the rod in the binnacle:
Here comes the fun part. I was trying to figure out the best way to attach the cables together to pull the new one through. I don't know if it has been done before, but here is what I came up with:
Went to Ace Hardware and bought a 10-32 connecting nut ($4.50). On the new cable, thread the jam nut on all the way, then spin on the connecting nut... all the way. Install a short piece of the appropriate diameter heat shrink tubing over the end of the new cable. Butt the end of the old cable to the new and thread the connecting nut on it. Tighten the jam nuts and shrink the heat shrink tubing with a heat gun. I did all this on the binnacle side, thought it would be easier with only one person to pull from the transom side, and it was. The pull literally took 60 seconds, and it was all the way through.
Well... there's your problem...
I figure I had maybe one more trip on this cable before it broke completely. As I was coiling it up to put it in the garbage, the end snapped in half.
Here is the cable pulled through the transom. I did put about four or five wraps of electrical tape as indicated on the pic, just to soften the edge a bit:
Remove the heat shrink and put everything back together. Right after I first got the boat I always noticed that smaller (end) rubber boot on the cable wouldn't stay put, and I think that may have contributed to the failure. I added a couple of zip ties to keep the boots in place.
And the part# on the old cable, just for verification:
I was really shocked at how easy the cable pulled through... I was prepared to spend all day with this and like I said, I was done in an hour.
I was so encouraged by the luck I was having, I decided to pull up the hydroturf under the drink holder (above the head) and install my new SeaDek faux teak panel. That took another four hours...
As bad as I want to do it... I will definitely wait for winter to tackle the swim platform!
One last note... the mobile version of this site ROCKS! I referenced it three or four times while I was working on the boat to make sure I was putting stuff back together correctly. Thank you [USERGROUP=3]@Administrative[/USERGROUP] !
Thanks for watching... I hope it can be of some help to those that choose to tackle a shift cable replacement.
L8R
Crescent Wrench
Channel Lock Pliers
Needle Nose Pliers
Heat Gun
Jetboaters.net
Parts:
L8R
